Flight Issues
toddw
HI - Just returned from two flights.
On the first flight: I got a notice Strong Interference to Aircraft and it automatically started flying on RTH. Any ideas on what would cause this. I could still see it.
LOG:
A 00m 00s 0.0 ft 0 ft Mode Mode changed to 41
B 00m 00s 0.0 ft 0 ft Tip Tips__Taking Off
C 00m 00s 0.0 ft 0 ft Warning The aircraft is in a Warning Zone (Class D). Fly with caution here.
D 00m 01s 0.0 ft 0 ft Mode Mode changed to AutoTakeoff
E 00m 01s 0.0 ft 0 ft Tip Tips__Taking Off
F 00m 04s 4.3 ft 2 ft Mode Mode changed to GPS_Atti
G 01m 34s 86.6 ft 774 ft Data Loss Downlink data connection lost for 5.2 seconds
H 01m 34s 86.6 ft 774 ft Mode Mode changed to GoHome
I 01m 35s 86.6 ft 774 ft Warning Strong Interference to Aircraft
J 02m 20s 184.1 ft 1 ft Mode Mode changed to AutoLanding
K 02m 20s 184.1 ft 1 ft Warning Obstacle Avoidance will be disabled in landing. Fly with caution.
L 02m 57s 21.3 ft 6 ft Tip Tips__Landing Canceled
M 02m 58s 21.3 ft 6 ft Mode Mode changed to GPS_Atti
N 04m 02s 17.4 ft 6 ft Mode Mode changed to AutoLanding
O 04m 02s 17.4 ft 6 ft Tip Tips__Aircraft close to Home Point. "go home" shifts to "landing".
P 04m 14s 17.4 ft 4 ft Mode Mode changed to FORCE_LANDING
On the second flight: I lost the camera about 20 feet from landing. It just went blank. Any ideas on what would cause this? I reset the mavic and it came right back on.
LOG:
A 04m 17s 0.0 ft 0 ft Mode Mode changed to 41
B 04m 17s 0.0 ft 0 ft Tip Tips__Taking Off
C 04m 17s 0.0 ft 0 ft Warning The aircraft is in a Warning Zone (Class D). Fly with caution here.
D 04m 18s 0.0 ft 0 ft Mode Mode changed to AutoTakeoff
E 04m 18s 0.0 ft 0 ft Tip Tips__Taking Off
F 04m 21s 3.6 ft 1 ft Mode Mode changed to GPS_Atti
G 05m 54s 386.8 ft 229 ft Warning Warning:Max Flight Altitude Reached. Adjust in Main Controller Settings if necessary
H 06m 42s 387.5 ft 529 ft Data Loss Downlink data connection lost for 4 seconds
I 06m 42s 387.5 ft 529 ft Warning Warning:Max Flight Altitude Reached. Adjust in Main Controller Settings if necessary
J 07m 56s 387.1 ft 915 ft Warning Warning:Max Flight Altitude Reached. Adjust in Main Controller Settings if necessary
K 13m 08s 387.1 ft 2,013 ft Warning Warning:Max Flight Altitude Reached. Adjust in Main Controller Settings if necessary
L 14m 21s 385.8 ft 533 ft Mode Mode changed to GoHome
M 14m 21s 385.8 ft 533 ft Tip Tips__Return-to-Home Initiated
N 14m 46s 384.5 ft 1 ft Mode Mode changed to AutoLanding
O 14m 46s 384.5 ft 1 ft Warning Obstacle Avoidance will be disabled in landing. Fly with caution.
P 15m 47s 11.5 ft 3 ft Mode Mode changed to GPS_Atti
I have noticed all the videos are automatically recording to my dji go 4 app. Is there any need to hit the record button on the controller?
First log, calibrate compass
Second log, You are near a no fly zone.
Hi Mako79, I called the local airport with notice prior to flight but any ideas as to why it's losing connection so close and flying back?
Either there's strong RF interference at that location, or either the controller or aircraft is defective. Try in a (very) different location.
iconautomatedsolutions
