How can I launch and return my MA2 3 miles out at sea, have it follow the boat, then return it to boat safely? Thanks
YesHow can I launch and return my MA2 3 miles out at sea, have it follow the boat,
That depends ...... then return it to boat safely?
Very helpful information and much appreciated!! JYes
That depends ...
Out at sea, you are flying in an unforgiving environment and not the place to learn new techniques.
One mistake can easily be one too many.
You need to be familiar with everything you will be doing with the drone from practice on land before attempting it at sea.
You'll need to be hand launching and hand catching.
You'll also have to be careful if the boat is moving any distance and avoid getting to a point where the drone wants to leave you and return to where it was launched, because of the distance and battery level.
Prevent this by resetting the homepoint to the drone's location every few minutes.
And allow a generous safety margin, returning to the boat early as it might take longer than you expect to catch the drone if the boat is moving.
This is fantastic advice thanks! One question, how do I set the home point to lead to the Controller? In advance...thanks. JCouple things you go right off the bat, Minimize your risk by getting a Rescue Jacket for the Air 2s since you have the boat. Second set your home point to lead to the Controller. .
Take a preflight over the Water with the Rescue Jacket to see if you run into signal loss or geo areas,
Knowing there is a weak signal area can provide the insight need to get around it.
The Rescue Jacket will take a lot of the stress away and provide 3000 Ft visual line of sight.
Phantomrain.org
Gear to fly in the Rain and Land on the Water. Phantomrain.org
All makes perfect sense and will be very helpful. Love the top gun idea????It can certainly be done, but the driver of the boat has to work with you.
For Launching, wait till you have enough satellite signal, then hand launch and immediately climb away from the boat. If the boat is moving, do this off the back. KEEP CLIMBING once you launch, because once you are out over the water you're committed. If possible, do this when the boat is anchored or at least not powering ahead.
Best keep VLOS while you're up(for real!), and remember depending on the drone, the boat, and the wind, you might not actually be able to keep up with the boat if it's going full throttle so again, make sure the driver of the boat is on the same page as you.
To Land on the boat, you MUST be confident while dropping in for your final approach. Make sure the driver of the boat is going as slowly as possible, or dropped anchor, etc; the drone can hover in place but the boat cannot. Don't be afraid to grab the drone by the main body when it gets close- it might be the only wait to stop it from going into someone's hair!
Lastly/most importantly, make sure you launch with a 100% FULL BATTERY and you bring it back with plenty to spare; chances are you will need to try your landing approach more than once...
I did this with a Mavic Mini last summer and would have tried it with the Air 2 this past weekend, were it not for inclement weather. With the Mini, I snatched it out of the air to land because the pontoon boat we were on was full. It also helps if your buddies get the "Danger Zone" Top Gun theme going with the bluetooth speaker to cheer you on.
Best of luck!
{#_#}
That's not possible, but on a boat you won't want use the return to home feature anyway.One question, how do I set the home point to lead to the Controller?
Keep the drone packed away and hang a GoPro off a kite, fly it behind the boat and then haul it in …….. ? ? ? ?? ?How can I launch and return my MA2 3 miles out at sea, have it follow the boat, then return it to boat safely? Thanks
All possible, except for the “safely” part.How can I launch and return my MA2 3 miles out at sea, have it follow the boat, then return it to boat safely? Thanks
you could practice hand catching while skate boarding.the drone can hover in place but the boat cannot.
...If I had or rode a skateboard. I've done it on inline skates and on a bike, tho. Last year on the pontoon boat, it was my first time doing it; no practice at all. The boat was full of little kids, parents, bagpipes, and drums- no room to attempt a proper landing. I just had to trust my eyes and not let it land on my son or any of the other kids! In the end it was not a big deal. I imagine that the Air 2 will do better, being a more capable machine than the original Mini.you could practice hand catching while skate boarding.
Could be mine! Cheap insurance, imo. Quick install, easy to use. If you fly a mavic over water, get one. There is a forum discount too.
MA2 317" data-source="post: 1290518" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">You can update the Home Point in the app to where you are at with a GPS enabled device.
It's not a follow me feature, it just updates the HP to your device.
If you get further away from your original HP, the low battery RTH may kick in and want to go there unless you update the HP to you a few times during the flight.
Blow the map up during the flight and the HP selection is on the right with two options. Reset the HP to the aircrafts current location or the device.
It's not a one and done thing so keep updating as you move.
