Gimbal will not hold the horizon/ YAWs without stick input
Unfortunately for the op, another example of calibrations not solving the issue.
Hope you get this solved.
Reactions: pmshop
I had a yaw issue with my MA for quite some time and fixed mine with a stick recalibration. It looked centered in the log just like yours, but it was not. There is no way for the system to know if the stick is centered. It just records if the stick deviates from the calibrated position.
It wasn't the stick - the flight log posted earlier shows it properly centered.
You misunderstand what is recorded in the log. The rudder output, not the physical stick position, is what is recorded in the log file, and it was zero for most of the flight, so no yaw was commanded, by definition.
Reactions: WooZie
Hi!
I am new here. My first post. I also have problems with horizon level. I have small crash a month ago but after that everything was fine. This horizon level problem started few weeks ago. First the horizon is usually at level but then it tilts and dosen't come back to level. Everything looks fine, all parts are in place, every calibration has been done few times.
Here is photo from this morning.
camposbrito
