Goggle box size
Can someone tell me the dimensions and weight (with goggles) of the box that the goggles come in?
Thanks!
TD
The box weighs about 1880g. Probably a few grams more if you add the charger and cables that aren't included with the weight measurement. So it would probably be closer to 2 kg.
The box's dimensions are, 28.3cm X 18cm X 27.7cm.
Reactions: Former Member
an unopend goggles box (brand new) is 4.5 lbs. The package, as shipped to you, in an exterior box, is 5 lbs.
ppdecs
