Been flying an Air S2 for a few years and I’m waiting on delivery of my Mavic pro
mavicpilots.com
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
trust.pilotinstitute.com trust.pilotinstitute.com
faadronezone-access.faa.gov
If you are considering acquiring your Part 107 License, here is a link to get you going…
Pilot Institute offers courses on drones and airplanes from world-class experts. Pass the Part 107 or Private Pilot exam and take to the skies.
pilotinstitute.com
Since you live in USA, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
44809 is an exemption from Part 107 drone laws. This means that drone pilots fly under Part 107 drone rules by default unless they meet all 9 of the requirements to fly under 44809, the exception for limited recreational operations of unmanned aircraft. You can read more about these requirements...
pilotinstitute.com
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below are the links to all of the downloads offered by DJI for the
Air 2S and the
Mavic 3 Pro, including the User Manuals.
After you read the Manuals, read then again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Learn and download DJI
Air 2S related apps, software, and manuals at the DJI Download Center
www.dji.com
Mavic 3 Pro related apps, software, and manuals at the DJI Download Center
www.dji.com
Fly On and Fly Safe…
