GPS Not working
Fastpilot
Hello fellas. When I turn my air on, I see NO sattalites on the screen. It is always OPTI mode. I can fly without any problem in this way. I am suspecting about my GPS module is broken. How can I check if the problem is in the module or not. What do you suggest ?
I soldered some cables to battery terminal inside of the drone. ( other ends of battery terminals ) Thoose cables goes to outside. So I can use additional battery in parrallel with original battery. While doing that, drone fall to the ground as twisted ( over the GPS - yes top cover was open - ) from about 30cm height. Probably this happened that time. But I canno be sure it is a broken gps or something else.
Visually it looks fine. How can I test if it is working or not ?
Turn on the Air without the GPS/compass connected and see what it does, and any error messages.
Do you have a replacement GPS unit you can try?
with or without module, Air's main screen is same. Gps sattelite sign is inactive. Everything else is functioning properly. I dont have replacement module.
Have you determined that the extra battery will provide more flight time despite the extra weight?
we had a damaged gps due to impact. the rear shield was pushed in
symptoms : 0 satellites - no errors
suspect new gps module will help
I am talking for Mavic Air. NONE. Additional batteries will not help. I tried different size and capacity batteries, they dont work. Stay with original.
RobertCNewman
