Greetings from a new drone owner
RCarnelian
Seattle, WA
Hello from the Seattle, WA area.
I’m an artist / animator who retired from game development a couple of years ago. Still interested in being creative and learning new technology, but ideally outdoors doing real things instead of at a keyboard making digital stuff (or less of the digital stuff, at least).
During the pandemic a rock hounding friend roped me into coming along. Fast forward to last fall, we ran into another hound at a favorite location. They described a large pit we HAD to check out. It’s in an area that was clear cut about 10 years ago. We hiked old logging roads and paths and did our best but could not find that pit. Online maps, satellite images, etc., were also a dead end. Eventually the idea of a drone came up.
It was enough of an excuse to start researching the possibility. The potential for creativity and learning and more was super exciting.
So, I recently bought a Mini 2 as a first drone. It seemed the best fit for a beginner with some room for growth. But I wouldn’t consider myself even a beginner yet. There’s so much to learn. It’s going to be a while before I try flying a drone above that clear cut area. That is, if it’s safe and allowed. For now, it’s fascinating to learn about drones and safe flying.
Welcome to the forum! :)
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Washington, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Fly On and Fly Safe…
Thank you for the thorough reply. I did get the TRUST certificate and have looked into state, county, and city regulations. But that's about it. So, your links and comments are very appreciated.
Reactions: LoudThunder
Welcome to the Forum From Bakersfield!
Head the above advice and read thru the posts on this forum and you will be Flying comfortably in no-time!
Welcome. As far as the 'pit' is concerned, I might be telling you something you already know, but Google earth has a time function, look for an icon on the edge of the map frame that looks like a stopwatch. Hit this and you get a time slider pop up, you can choose historic aerial photomapping datasets. What I'd do is scroll back through the years to 2010/18 and look for large scale canopy denuding in the general area. That might give you a target to aim for. Good hunting.
TPS
