Greetings from Fayetteville, Arkansas
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
I’m a new Part 107 pilot with a Mavic Air 2. Lots of fun to fly. I have much to learn about the drone, it’s photographic capabilities and editing!
Welcome to the forum from the mountains of Colorado! We lived in west Little Rock for a few years. Nothing personal, but we sure don't miss that heat and humidity, and especially the tornadoes back there. Happy and safe flying!
Welcome from the Hampton Roads area of Virginia, USA. I am a Mini 2 Flyer and I know the excitement of flight. So, if I may offer some advice.
Below is the link to all of the downloads offered by DJI for the Mavic Air 2. You will also find the 57-page User Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
https://dl.djicdn.com/downloads/Mavic_Air_2/Mavic_Air_2_User_Manual_v1.6_enIII.pdf
Happy and Safe Droning…
Welcome to the forum! :)
Hello from Minnesota and welcome to the Forum....congratulations on your DJI Air 2....There's a lot of good quality teaching/feedback going on in here. Just ask, and the experts are great on providing good sound advice for you to apply and use... Remember to always Fly safe and Fly Smart, always in VLOS to reach that level of safety also control.
Greetings from Birmingham Alabama, welcome to the forum!
tyroe1998
