- Joined
- Nov 21, 2017
- Messages
- 26
- Reactions
- 1
- Age
- 66
Hi ! I did not find any comprehensive manual for GS Pro so I ask some questions here:
Setting up a new mission as "Waypoint Flight - Route" with "Aircraft Record Altitude":
As far as I understand you then fly the drone and tap "Set" where you want to have the waypoints.
Are you able to set to correct gimbal setting also ? This would be perfect as there is no need for a good quality Google Earth Map.
Has anyone done this ? Your experience ?
When flying the mission, does the drone then adjust height and gimbal setting smoothly between the WPs or in steps ?
Does it work with waypoints below take off height (cliffs) ?
Thanks for your input.
Robert
Robert
