Hello everyone
mikedp
Louisiana
About to buy the mini 4 pro combo, but I want the "under 250 grams" package. I understand the "plus" batteries will send the unit into the "over 250 class" therefore requiring registration. How can I tell if its the lighter batteries? Someone said that if says "ultra light 249g" its a non-registration drone. Any help is appreciated. Thanks.
it's pretty easy to see which battery is which. I think the Mini 4 Pro combo sends 3 standard batteries. The Plus batteries have to be ordered separately, IIRC
honestly, I don't see what the big deal is about registering with the FAA. It's easy to do and $5 allows you to register multiple drones for 3 years
info on registering here:
https://www.faa.gov/uas/getting_started/register_drone
FAADroneZone
easy-peasy
and, you can have free FAA labels printed and sent to you by the great folks at the Pilot Institute
Free FAA Drone Registration Stickers - Pilot Institute
the labels are small, easily adhered and look professional
the labels
Reactions: Cafguy
All of the above is true. A big welcome to the forum from the UK!
Reactions: Cafguy
The lighter (standard) battery has "249g" printed on it's arse in grey ink. An unmarked battery is the 'plus' heavier version. You'll find this an excellent entry level drone.
Reactions: Cafguy
DJI sells two Mini 4 Pro combo versions. The more expensive one is all Plus batteries and the cheaper one is all regular batteries. Which battery you fly with determines whether or not RID is broadcast, and whether registration is required. You must fly with Mini 4 Pro regular batteries to prevent RID broadcasting, and stay under 250g, and exempt from registration when flying recreationally.
Reactions: Cafguy
If you still need help, let us know where you're planning to buy from any we can point you to the correct package.
Mohzus
