Hello fellow droners. Im new to this site and mostly new to the whole drone community
SwankyPants
Sweden
I just wanted to say hi to everyone. I got my hands on a cheap Mini 2 SE that was totally busted up. A few £ on ebay with a new chassi and a new complete gimbal and it's ready to fly again. Been learning the basics down at work for a few days so i haven't recorded much yet. But i'd like to share the small stuff i've got this far :DDJI_0055.JPG
Welcome to the forum! :)
Since you live in Sweden, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 2 SE, including the User Manual.
Fly On and Fly Safe…
Thats a great write-up for first time flyers and also experienced but still newbie flyers. Yeah we have some regulations in Sweden, mostly regarding bigger drones. Since i live kind of up north there is only one NFZ in the nearest miles and thats the airport, drones got alot of workaround regulations regarding Airspace. Since the Mini2 is under 250grams the only real education i need is to "Read and understand the manual", the weight-class under 250g is mostly just common sense. I've already learnt alot how it handles, where there is alot of interference and such. Love this little thingy
proya12
