Hello from Alaska
Alaska
New to the forum, not new to DJI drones (or crashing them from dumb mistakes). Thinking about buying a Mavic 3 Thermal for always-powered-on operations and looking forward to chatting about that once this thread gets approved by moderators. If I do get the M3T then I'll need to quit my habit of crashing the drones into trees because that thing is just too expensive for that bad habit. I might have to finally get good at flying these things for once.
Happy to be here!
Greetings from Birmingham Alabama USA, welcome to the forum!
Since your thread was posted, it was approved, you will be given guidance about the rules, by one of the moderators...
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot. I have now passed my Part 107 License Exam and am awaiting the arrival of my Permanent License and then I will re-register my Mini 2 under Part 107.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Alaska, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Even though you have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic 3 Enterprise, including the User Manual.
Happy Droning…
Welcome to the forum! :)
Happy to be here!
Welcome to Mavic Pilots from Dayton Ohio USA! Fly safe and have fun!
ianscott
