Hello from Annapolis, Maryland
ampmphotos
Annapolis, MD
New pilot checking in, eagerly awaiting the arrival of the Mavic Air2. Reading many forums and finding very good tips along the way. So much to learn, never flown a drone before.
Question: When my "new to me" drone arrives, can I quickly pull the data of total distance or hours this drone has flown?
Thank you in advance, Andy
Hello from the Hoosier Heartland ampmphotos.
Yep.
It records every flight and the logs are accessable in the app.
Read the instruction manual for more information about the flight logs.
For the nitty gritty about a flight, follow the instructions here for more information.
Take it easy and don't get over confident with yourself until you get some additional stick time..
Other members will be along soon with additional information and welcome you. ?
Welcome to the Forum. :cool:
Welcome to Mavic Pilots!:) Enjoy the forum!Thumbswayup
Hi ampmphotos Welcome to Mavic Pilots.
New flyer advice,
Wide open space.
Slow & easy
Power-lines & trees are evil.
Don't expect RTH (Return To Home) to save you especially if you are under trees.
Don't forget to read the manual ;)
Download Air 2 manual HERE
Thank you so much. All good points that I will heed ....
Yep.
Thank you so much! Very helpful.
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching .
Thumbswayup
Welcome to the forum! :)
Here are some things to help you get started with your Mavic Air 2:
  • The current Mavic Air 2 manual can be downloaded here (it doesn't come in the box). Other important documents can be found on the Mavic Air 2 downloads page.
  • Check out this getting started guide for some tips not found in the Mavic Air 2 manual.
  • Your drone batteries will last longer if you use and maintain them like this.
  • Practice flying outdoors in a wide open location that's free of all obstacles. Don't attempt to fly inside your house or in other confined locations.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
  • Check out MavicHelp.com for commonly used accessories you might need.
Flying S
