Hello from BC!
Welcome to the forum! :)
Hi there! I work in the forestry sector. I'm about to recieve a Mini 3 Pro via mail, and I've started working using the company's Phantom 3 Pro.
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current. Depending your status, government worker of private sector, the rules may vary for you…
This web site is a great place for advice and information about your New, Yet-To-Arrive, Mini 3 Pro… but for the Phantom, you might wat to join our sister site too…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Hi there! I work in the forestry sector. I'm about to recieve a Mini 3 Pro via mail, and I've started working using the company's Phantom 3 Pro. Still new to this, but would like to progress and make legitimate leaps in using UAV GPS and imagery for forestry use!
hello from a fellow Canadian! Welcome!
GrantleyB
