Hello From Clovis California
GuyAdams
Clovis
Hello Everyone. I’m knew to flying drones. I bought a used Karma years ago & it just sat. Finally a year ago I started flying it & was hooked. I recently stepped up & bought the DJI Mavic 3 and I’m having a blast after getting over the fear of losing it to fly ways after reading so many reviews. I excited to find this forum.
Enjoy Your Day
Guy
Saturday Flight To See The Clouds
You don't say if you've gotten your Stuff done, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs more than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are still required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in New Mexico, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic 3, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum! :)
Thank You. That’s a lot of information. I am going to through it & get it all done. I did register my drone at FFA Drone Zone. Once again, Thank You
CMDR DV TEARDROP
