Hello from East Tennessee (USA)
jhatfield
Johnson, TN, USA
Greetings,
Currently I purchased a DJI Mini 3 Pro (dji RC) and am most excited to be back in the air once again after a couple of years on the ground. In 2017 I bought a DJI Phantom 3 Pro. Several years back, due to pilot error I sent her into a tree some 80 or so feet up. Spent sometime and effort trying to put it back into the air again, but so far I haven't been successful. I saw a DJI Mini 3 Pro several weeks back and tried to talk myself out of getting it, but my wife bless her heart encouraged me to go out and get it. At the age of 69, I know my ability to adapt to change isn't as tolerable as when I was younger, but I'm not ready to sit on the sidelines and watch yet.
Very pleased to be here,
Jerry
@jhatfield welcome to the forum
you will be amazed at what you will discover you can achieve anything if you put your mind to it ,I started flying drones in particular ,around 6 years ago when i was your age ,and the pleasure it gives me ,far outweighs the small amount of effort it requires to gain the necessary skills ,to be able to fly your drone in accordance with your particular countries rules and regs
Hello from the Crossroads of America jhatfield.
Nice to meet you Jerry. 🤝
In case you haven't done it yet, you should take the TRUST test and keep a copy with you when you fly.
It's a free, no fail test that's easy to pass.
Welcome to the Forum. :cool:
Greetings from Birmingham Alabama USA, welcome to the forum!
As a New, New Drone Pilot, the rules, and regulations have changed over the years and there are a couple of Legal Things you may need to do…
MA2 317 has already given you the heads up, but I will say it again, If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs less than 250-grams (0.55 pounds) and if you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in "East Tennessee in the USA", there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy Droning…
Greetings,
Jerry
Don't worry. I'm 77 and I still like new things/toys, and I still like to fly my Air 2S.
WELCOME to the forum from the other side of the Blue Ridge Mountains :)
Welcome to the forum! :)
Reactions: LoudThunder
Greetings,
Jerry
Greetings from Colorado, USA🇺🇸, welcome to the forum🎄
JefScot
