New to Drone flying, just recreational flying with the Dji
Mini 3 Pro and
Mavic 3 Pro.
mavicpilots.com
You have already written that you've received your TRUST Certificate, and that you've registered your drones. The FAADroneZone is also the Web Site where you will need to get any Authorizations if you plan to fly in Certain Controlled Airspace like military installations, etc…
faadronezone-access.faa.gov
If you are considering acquiring your Part 107 License, here is a link to get you going…
Pilot Institute offers courses on drones and airplanes from world-class experts. Pass the Part 107 or Private Pilot exam and take to the skies.
pilotinstitute.com
Since you live in Georgia, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
44809 is an exemption from Part 107 drone laws. This means that drone pilots fly under Part 107 drone rules by default unless they meet all 9 of the requirements to fly under 44809, the exception for limited recreational operations of unmanned aircraft. You can read more about these requirements...
pilotinstitute.com
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below are the links to all of the downloads offered by DJI for the
Mini 3 Pro and the
Mavic 3 Pro, including the User Manuals.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Learn and download DJI
Mini 3 Pro related apps, software, and manuals at the DJI Download Center
www.dji.com
Mavic 3 Pro related apps, software, and manuals at the DJI Download Center
www.dji.com
Fly On and Fly Safe…
