Hello from Manila, Philippines!
Welcome to the forum! :)
newbie Drone Pilot here from Manila, Philippines. I use DJI Mavic Air 2s.
Since you live in Manila, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Air 2S, including the User Manual.
Fly On and Fly Safe…
Hey welcome. New member here also and new drone pilot. I am from Montreal Canada but I am Filipino, born in Quezon City, grew up in Manila and immigrated to Canada when I was 10 years old. That was 50 years ago. Getting cold here now and will soon experience flying in the winter months when the temperature is within the manufacturer specs. I have a newly purchased air 3 and mini 4 pro. Recently also took the required pilot license here in Canada to fly drones over 249grams. Would like to hear and hopefully some posts of your adventure in our beautiful country.
Thank you for the warm welcome everyone. Looking forward to everyone sharing their adventure pics and/or videos. A lot to learn I must say, not only flying the drone but also making scenematic videos. Been playing around with LightCut but want to explore Dlog and researching what I need. Any suggestions will be much appreciated. Thanks
Welcome!
What's your experience in flying birds with a remote?
Rod
Hi Rod. If you mean birds in the area of your flight area, then try to avoid them. In fact if I hear squawking then I don’t fly in the area. I have limited experience on how they will react with the drone. At this time of the year, there are tons of canada geese in lakes and river here. At one time after I have taken off I heard them. So I put it in sports mode and then off I went high to a far distance. I couldn’t set up the area that I wanted to record for fear of the birds potentially attacking the drone. On the way back, I went full speed horizontally and then on descent for landing. Btw I am also a photographer; wildlife, landscape, portraits etc so I am so excited with the drone having the reach and the perspective it can provide.
Hi everyone, newbie Drone Pilot here from Manila, Philippines. I use DJI Mavic Air 2s. Hope to learn more from this forum. Thank you.
Welcome from Savannah, GA!
You found a great site to answer questions. Good luck and I hope to see some awesome pics from your side of the world! :)
mliamis23
