Hello from Michigan
Greetings from Birmingham Alabama USA, welcome to the forum!
I just purchased a DJI MINI SE drone to take aerial landscape shots for a guidebook
Paul, I've got some NEWS that you need to pay attention to and that is you need to get your Part 107 License to take those landscape shots for that guidebook.
I've included the link to getting your TRUST certificate but it is only for you to fly your little drone for fun. Those photos that you take for the guide book will be considered a commercial enterprise and that requires a license and that link is blow also.
But before you throw in the towel, you need to learn to fly your drone safely and for fun…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Michigan, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini SE, including the User Manual.
Happy Droning…
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to Mavic Plots! :) Enjoy the forum!Thumbswayup
My name is Paul. I'm a freelance travel writer, and I just purchased a DJI MINI SE drone to take aerial landscape shots for a guidebook I edit. I've done a fair amount of photographic work on land with a DSLR, but this is new for me. Any pointers are welcome!
Welcome. Nice to see a “near Detroiter” who’s also a photographer. You’ll find great info and tips here.
Welcome to the forum! :)
Reactions: LoudThunder
Hi, another from Michigan. I'm on the west side of the state, north of GR. I do have my 107 Cert, if you wanted to get some shots around my neck of the woods I would be happy to show up and be the Pilot in Command (PIC) for you to legally use your drone photos for the guidebook. By being the PIC I can literally hand you the controls and let you fly/photograph, as long as I am watching the drone, making sure you follow laws, and can take over at a moments notice.
Also, I studied for 7 days for the 107, having no aviation experience, and was able to pass on my first try. I did buy an online course to study, but you can find almost everything on Youtube for free if you know what is on the test.
What @LoudThunder said about needing a 107, it isn't just if you are paid, it is if it is for advertising, promoting, pay, images used on a website, pretty much anything past photos of your kids or property for yourself. It's been discussed, but even if your neighbor asks you to check out his roof vents, that *could* be considered to be a 107 required mission if that was your intent when you took off.
But welcome to the forum. I have a P4P, Air2S, and a Mini2. The camera on the A2S really does help a lot over the Mini, but if you get the settings right, the Mini does a good job at still photos.
JefScot
