Hello from Michigan
Thank you, I am in the hunt for an ipad now, I see that you use the mini4. I need a bigger screen myself as my old eyes need something bigger than my iphone. Now do I want to spend for the mini or get the 10" ipad and insight? thanks
I used a mini 4 with the Spark and a little but with the MA2.
The Go Fly app was labor intensive on the mini 4 resulting in "High CPU usage" errors. It never quit but the screen was hard to see in the daylight, even with a four sided hood.
I've since purchased a Tripltek 7"PRO and satisfied with it. (Android OS)
Tripltek makes an 8 and now a 9, that has the brightest screen in the industry.
It's not cheap, and it's heavy, but it's the best for flying during bright days.
Welcome to the forum! :)
Welcome to our forum, from Hauptmann, in Hurst, Texas!
You'll love the flexibility of vantage points an aerial camera platform affords--you'll get shots and videos you could only dream of before! I fly a Mavic 2 Pro now, but will soon be upgrading to the Mini 3 Pro.
We have over 150,000 members—many, many from your part of the Midwest--who enjoy helping each other get the most out of our hobby. Most of the questions you'll come up with will've already been addressed, and are easy to search. If you have NEW questions, just ask!
I attached a couple of links below, which will help make learning piloting and photo/video skills easy.
BTW, I'd like to spend some time in Michigan. Only been to Detroit so far. Want to attend the Detroit Auto Show, and to drive around the state, especially the upper peninsula. Maybe next year.
Glad to have you with us!
Rich R (aka Hauptmann)
Welcome to the forum. We look forward to your participation and your view of the world.
I have taken the leap, purchased a few weeks ago the Mavic Air 2 used from someone that never used it. Been learning to fly it, so much to learn. I registered it so I am legal for now.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
You wrote that you registered your Drone, So your Drone is now legal, but you did not write that you had your TRUST Certificate. This you need if "YOU" really want to "be Legal…"
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) .
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Michigan, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic Air 2, including the User Manual.
Fly On and Fly Safe…
Welcome to Mavic Pilots!:) Enjoy the forum!Thumbswayup
Thank you for the thoughtful information, hmmm The Trust certificate is something that I didn't know. I did register it but will look into the Trust, thanks for the helpful link. I have spend the last couple of week going real slow, been learning how to fly and watching plenty of videos. I am so nervous about everything, but I am getting it ever so slowly. I printed off the manual and have been reading it, great advice, so many features on this Mavic Air 2 well at least to this newbie. Appreciate your links to the members will check that out. Happy safe flying.
Thank you more great content to watch and learn from thanks! Northern Michigan is where God was born, lol it is beautiful especially with the seasons. No mountains but we have lots of lakes and wonderful open country. Much appreciated
Are you a Yooper?
I've snowmobiled in the upper and lower parts years ago.
You are correct, beautiful areas to be found. 👍
brokerman
