Welcome to the forum from the mountains of Colorado! Happy and safe flying!New to the forum, new to drones.
Welcome from the Hampton Roads area of Virginia, USA. "New to Drones." Does that mean you have not yet acquired one? If not, go to YouTube and search on each type of drone you are interested in possibly buying. If you are interested in a DJI, please feel free to ask your question here. You will get your question answered and probably get information that you had not yet thought to ask…
As for me, I am a Mini 2 Flyer and I know the excitement of flight. So, if I may offer some advice concerning DJI Drones.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). Open the front legs, open the back legs of your drone, then remove the Gimbal Cover.
Place the drone down while it finishes its self-test (collecting satellites, etc…).
I would also advise you to use YouTube and watch a lot of the Videos on flying and setting up the Drone. When it is too dark, too cold, or too wet, you can "fly it vicariously" through YouTube. Also watch some of the Blooper Drone Videos and learn how not to fly your "New Baby;"
Happy Droning
