Hello from New Jersey
Hello from the Crossroads of America jettie1767.
If you haven't done it yet, you need to take the TRUST test and keep a copy with you when you fly.
It's a free, no fail test that's easy to take that covers the basics of flying a drone.
Welcome to the Forum. :cool:
Bought my first drone today, a DJI Mini 4 Pro
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
I read you have your TRUST Certificate
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in New Jersy, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
M5P
