Hello from North End Boston - Amateur Radio
WELCOME To the Forum From Bakersfield!!
First: Not sure how far you want to go in this hobby BUT that HAM license of yours will come in VERY VERY handy in your Drone adventures!!
Second: WIRES! I bet It can be done. I would be very concerned with all the wind under the drone for sure!! Props and string don't mix.
I would also check the Local laws....long lengths of wire can be determined to be detrimental to others around you Make sure your good to go.
I helped a guy on this forum that wanted to mount a small radio on his Drone and send it up as a "repeater" It worked BUT A balloon was much more practical.
According to the present philosophy of the FAA, you will need to be a pilot to do this. Despite radio being a hobby, the FAA will look at putting up the wire as a 'business' and require you to have a license.
Yeah, it sucks.
Just bought a DJI Mavic Mini 4K in order to place paracord & wire antennas for Ham Radio in the Trees.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
Since you live in Massachusetts, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Flying in and around your ZIP Code 20109 will be a nightmare… With just a quick glance, it looks like it is all in Zero Altitude Quadrants or as I call then "Drone Taxi Zones" meaning the you cannot fly without an FAA Authorization and Recreational Flyers do not get them…
Only you know where you actually are located and if you zoom in, there might be areas you can fly but those numbers on the graphic indicate the maximum altitude you can fly in those areas and there are a lot of Zeros…
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to the User Manual offered by DJI for the Mini 4K
Fly On and Fly Safe…
Yeah, it sucks.
I was kinda wondering about that one myself.
Reactions: LoudThunder
Welcome to the forum @RadioGreg! :)
After flying many DJI consumer drones since 2016 (I own most all of them), here's what I recommend you do (at the minimum) to get started with your DJI drone:
  • Skip buying a non-DJI practice drone and start with any of the DJI consumer drones (ideally the model you'll be flying most). While it's true DJI makes one of the most expensive consumer drones, you likely won't learn much about your DJI drones by flying drones made by other manufacturers. And then you'll be back to square one again when you finally decide to ditch the practice drone and start flying a DJI drone.
  • Before attempting to fly, watch some videos on YouTube.com to learn more about your drone. Search for something like "Mini 2 Beginner's Guide" (replace "Mini 2" with your drone model).
  • Read the DJI manual (available in the "Products" section of the DJI Download Center) from beginning to end (maybe a few times). You're certainly not going to remember everything, but it'll give you a good understanding of the available features and capabilities of your drone. And then you can go back to the manual or YouTube videos when you need to take a deeper dive into a specific topic.
  • Before flying in the US, you must register your drone with the FAA (if it weighs 250 grams or more) and take the free online TRUST test (I like this one).
  • When flying in the US, your drone must broadcast RID if it weighs 250 grams or more (or is registered with the FAA). Many DJI drones (especially the newer models) have that feature built into them. If you're ever flying a drone that does not broadcast RID (meaning it's not on this list), then you'll need to attach an external RID module like the Holy Stone or Ruko RID module.
  • Don't power on your drone or take off when within about 20 feet of any magnetic metal objects (like your car or rebar in concrete sidewalks). See more on compass interference in this compass calibration guide.
  • Before taking off, always review the drone settings in DJI Fly (or the app you're using) to ensure everything is set as expected. If you do plan on flying near any obstacles, ensure the RTH altitude is set properly in case your drone needs to automatically return back to the home point mid-flight.
  • Never take off before DJI Fly (or the app you're using to fly) audibly mentions or shows the home point has been set. The drone will attempt to fly back to the home point location automatically if it loses connection with the remote controller, so it's crucial to ensure that location has been set prior to takeoff.
  • DJI drones have a lot of awesome automated flight features. Use them with caution and never assume they are always going to function as expected (always be ready to take control if needed).
  • Sensors are great and they can help prevent your drone from crashing into obstacles. They are not foolproof though. Never rely on them 100% or assume they are going to work perfectly in all flight conditions -- or react the same way when flying in similar conditions from past flights.
  • Find a flat, wide open place to practice (free of people, trees, and all other obstacles). It's pretty hard to crash a DJI drone into the ground, so you'll likely have the best success if that's your only obstacle. Continue flying in this location (or similar locations) until you're able to control your drone without thinking about it (like riding a bike).
  • Make sure you can easily see your drone at all times (required by law in most countries). After removing all nearby obstacles, nearly everyone who crashes/loses a drone is either not watching it with their eyes or cannot clearly see where it's located.
  • The screen is chock-full of great information. Use it as a reference (sparingly) as you do when looking at your dashboard while driving a car. It's also a great tool for framing the perfect photo or getting your drone in just the right spot before hitting record. If you're mostly staring at the screen while flying, you'll probably have no idea where your drone is located.
  • Don't fly in sport mode until you're comfortable controlling your drone. You don't want to get into a situation where you need to maneuver quickly and aren't quite sure which stick to move (another reason not to practice near obstacles).
  • DJI batteries require special care that is unlike other batteries you commonly use. To prevent any damage to your DJI batteries, follow the tips in this DJI battery maintenance & storage guide.
  • DJI drones record a lot of useful information in the TXT flights. The logs are helpful for things like troubleshooting issues you experienced during a flight, locating a lost drone, and many other things. The TXT files can be found on your phone/tablet or remote controller (if it has a screen). See these instructions for more details. And then you'll need a tool like my free online DJI log viewer or Flight Reader (keeps your flight logs offline) to decrypt and access/view the data within.
I had a ham license I think in 1976, it was KA7BBP.
The Mores code thing, I bet I can still remember 80# correctly, live with somebody didn't work.
I remember the last one was somebody in California, just couldn't keep up.
BTW, Welcome to the Forum!!
I'm know as to be a real good goof ball?
When I do another post is going to another guy that Uses a Phantom to do the same type of thing👌
BTW, my goal is to make somebody smile, It makes your day!
Rod ..
Welcome to the forum from the beautiful woods of Maine!
Reactions: MA2 317
Greetings from Chicago the Windy City, welcome to the forum.
FLY SAFE & FLY SMART
Reactions: MA2 317
Hello Boston -
Need to learn the local rules of the road with respect to how and where I can use my Drone.
Any Hams here that are way ahead of me?
Thanks
AC1NY
North End Boston
IMO I feel it will be difficult to put up wires using the drone to do it. I'm also a ham and I've helped friends do an inspection of their towers and antennas using my drone to take pics and videos. Good luck and enjoy the drone!
Reactions: MA2 317
Humbug4
