Hello from northern Virginia
boxxer13
Fairfax, VA, USA
Hi everyone, I'm from northern Virigina, particularly Fairfax County, I'm still on my first drone, a Mini 3 Pro which I got about a month ago. Despite living in a no-fly zone, there is accessible airspace that's only a 15 minute drive west. I'm looking for more places to fly but I have so much fun flying the M3P that I still have to precision flying, but I'll get there. I got my Part 107 (still waiting on the official card) just to be on the safe or $afe side, but I'm still a newbie so I'll probably ask some stupid questions.
Welcome to the forum. It's fun communicating with other pilots here. Mini 3 pro is a great drone to play with. If you happen to look for a handy case to carry and protect it, check out our MM330 hard case. Enjoy!
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Greetings from Birmingham Alabama USA, welcome to the forum!
Welcome to the forum! :)
I am so sorry to read about your NOTAM restriction, SFC to 18,000', indefinite… But I would suggest that now that you are part 107, you consider requesting authorization and waivers through FAADroneZone, I cannot imagine that there are no commercial drones flying the that monstrous area. The worst case, the request is disapproved and no harm is done. Fairfax is mostly Class G Air Space, if you exclude the NOTAM No-Fly, I recommend you try something simple, under Part 107, request a waiver to perform a "roof Inspection" on your own home, not over 100' with a 1/10 NM radius. If approved, you get to fly around your yard for the duration of the waiver. If that works, ask for another, for longer, and wider a radius, and maybe higher…
I am still recreational , but I live in a Class D air space 4-miles from an Air Force Base, 4-miles from a commercial Airport, and 6-miles from an Army Post and I have waiver/authorizations all over the Hampton Roads peninsula, I request mine for all day-light hours, and for a year in duration. And I have had DJI grant me Geo Zone authorization for Zones and Height restrictions. As I wrote, it done sot hurt to ask.
Now we are taught that it takes up to 90-days for a reply and in your case it might very well be true. But in my case as I'm not trying to bust a NOTAM, I have had mine approved sometimes even the same day I submit them and the longest was only 3-days.
Now, one of lour members recently has a visit from the Secret Service for hi flying and it went all well, it's a recent event, you can read about it in the General descussions.
As for me, I am required to call ATC before my flights and sometimes I do not bother and I've had visits from the locals at the AFB. They have the equipment to read the telemetry from my Mini 2 and the signals from my controller, so they know where I am, and it happens so often, they know who I am…
So, the moral is they probably can read you telemetry and if you do try to have a "quicky" they might find you. So see if you can get some waivers… Remember, YOU ARE PART 107 LICENSED Now…
Ok now on to some lighter, like your droning…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy Droning…
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members willing to help you with any questions you have. As dirkclod said, search the forum using key words and if you don’t find answer, post your question and I’m sure you’ll get a quick response! Fly safe and stay safe!
Greetings from Frederick Md.
Thanks for the welcomes! Lately I've been practicing precision flying, taking it slow and learning the controls. Not being able to fly in the backyard sucks but I'm discovering new open fields to practice. Just waiting for the cooler weather to arrive. It's still warm enough for gnats to fly into my face.
I did a ton of research about the M3P as well as drone flying. If I'm buying a drone, then I better know what I'm getting into. I studied for the part 107 on my own so I think I got a handle of things and I even crashed once. It got hung up in some branches. I just need to log in more flight hours and get over that fear I get when I send it up (like 200 feet) and see it get smaller and smaller in the sky. Anyone know any quicks ways to get over that fear?
@boxxer13 ,really the best way to overcome your anxiety as a new drone pilot ,is to just go out and fly as much as you can, i think i speak for most on this forum ,when i say that its something we all went through at some point, when we started to fly our drones,the real secret is to not forget that things can and do go wrong sometimes, so do your pre flight checks ,make sure as much as possible ,that the location ,weather conditions ,and any possible flight restrictions ,that may be in place ,will not prevent you from flying ,and above all enjoy the flight ,from the moment you take off, till you get safely back on the ground, every flight is different ,thats what makes this pastime so great ,
Roel Hopstaken
