Hello From Scotand
Welcome to the forum!
So your experience with these birds that you control with a remote is, um, pretty low?
I cant figure out the correct wording. :rolleyes:
Anyways,
Stay away from Mavic Magnets (🌲) 👌
Rod ..
This forum was recommended to me by a member from elsewhere
Welcome from the Hampton Roads area of Virginia, USA. So glad you could join us. As I wrote earlier, on the other web site, you will find lots of friends here and I see you've got a good start…
We have a Member's Map in the Upper Right of the Title Bar. Click on "Members" and then Click on "Member's Map…" Check it out and you might find some new flying friends.
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
As a Newbie, here is some Good Old Fashion Advice…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
gimfbsx
