I am still researching what to buy but it appears the
Mini 3 /Pro is a good start.
mavicpilots.com
You will receive a lot of wonderful advice on the pros and cons of various drones. You will just have to decide how much the various features (Photo Resolution, Video quality, obstacle avoidance, flight time, etc..) are worth to you. The more you want, the more it costs and you have to consider the legal ramifications of (registration, licenses, etc…) of owning larger drones.
Go onto YouTube and view the various Reviews, since some of the drones have been out a while, the videos may be a few months to a year old… Don't forget that the device you use, Smart Phone, Tablet, etc… has to support the DJI App. So check that also. Few things more disappointing that to anxiously await the delivery of your drone only to find out that you cannot connect it to your device.
So, find out what app is needed for the drone you choose and down load it and make sure it runs on your device… It will not do much but it will open up and function if all is compatible…
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Find out what you need to know and do when you fly drones or model aircraft in the UK
register-drones.caa.co.uk
Once you decide on which drone, here is some Good Old Fashion Advice… And since you mentioned the
Mini 3 Pro, I've included the link to all its downloads, including the user manual…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the
Mini 3 Pro, including the User Manual.
Learn and download DJI
Mini 3 Pro related apps, software, and manuals at the DJI Download Center
www.dji.com
Fly On and Fly Safe…
