Hello from the La La Land (Golden State)!
CosmicCruiser
Los Angeles
Hey everyone!
Just a quick hello from sunny California. I've always been fascinated by flying and the freedom it represents. That's why I'm thrilled to share that I'm currently studying for my Part 107 license exam! My goal for this year is to become a Certified Remote Pilot and explore the skies from a whole new perspective.
Wish me luck on my journey, and I can't wait to share my progress and experiences with you all.
It does not sound like you have been a long time drone pilot so I will share treat you as a New Drone Pilot and there are a couple of Legal Things you may need to do…
Until you actually pass the Part 107 exam, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). If your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
Norsmith
