Hello from the Western Suburbs of Chicago
Johnb4604
Warrenville, Illinois
Hi, I am an older retiree who is brand new to DJI coming from racing drones and helicopters. I spend most of my time on RC Groups with the same user ID. I did some research and recently purchased a Mini 3 Pro with the RC remote controller. I am anxious to get flying but the weather has not cooperated, at least for a beginner. I am glad to join and hope to learn a lot! any help is much appreciated!
WOW.
Nothing yet on this thread.
Rod ..
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds) with the small batteries, and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Illinois, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
From CA - @Johnb4604 - Thanks for joining us @ MP! Great to have you.
I think you'll find lots of helpful info here. Also, scroll down the forum list. You'll find a forum area for your drone. Enjoy your stay!
calos69
