I live in a small town in Powys, Wales and just this week bought my very first drone, a
mini 2
mavicpilots.com
Since you live in wales, there are specific laws and rules for you to follow, please check to ensure these are current.
According to CAA, drones are allowed in the UK, subject to CAA regulations. Read on for more details.
drone-laws.com
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mini 2, including the User Manual.
Learn and download
DJI Mini 2 related apps, software, and manuals at the DJI Download Center
www.dji.com
Happy Droning…
