Hello From Washington State, USA
GrowingPlanetMedia
US - Washington
Site
www.growingplanetmedia.com
Just a quick 'Hello' from a former WA State and CO State professional photographer. I got out of the business, but am finding enjoyment and exploring possibilities with drones.
I have lots to learn about drones and working on my 107.
Thanks.
Greetings from Birmingham Alabama USA, welcome to the forum!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum! :)
Let us know what you are flying…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot. I have now passed my Part 107 License Exam and am awaiting the arrival of my Permanent License and then I will re-register my Mini 2 under Part 107.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Washington State, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Happy Droning…
Happy Droning…
Thank you for your time and care with your advice and recommendations! Yep. ENTRUST in hand, M3P registered and planning to get my 107 before my birthday - Jan 2. LOL!
I will definitely checkout the other sites you recommend. I am looking forward to learning more about this world of drone flight!
Thanks.
Welcome to the forum from the windy Colorado Rockies! Happy and safe flying!
paul44509
