Hello from Washington State
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum! :)
Reactions: LoudThunder
Welcome to the forum. You went way back with DJI as you still have Spark. Mini 3 pro is a huge leap over Spark. It's night and day. If you happen to look for a handy case to carry and protect it, check out our MM330 hard case. Enjoy!
Reactions: GFields
Owner of a DJI Spark (2019) and now a DJI mini 3 pro.
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
As a New Mini 3 Pro Pilot, there are a couple of Legal Things you may need to do that you did not do with the Spark…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Mini 3 weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, so you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Washington, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy, Safe and Legal Droning…
Thank you so much for your reply! I do plan on never flying beyond VLOS since that is the rule here and in regards to learning the ins and outs of the mini 3 pro, I purchased this book on Amazon; very good reading!
Looks like an interesting book. If you find it helpful, or not, write up a review and include some snapshots of some of the pages and post it in the "Mini 3 Discussions" forum.
Remember, in my initial "Welcome Posting," I included the link to all the DJI Downloads for the Mini 3.
I am a more visual person and I prefer a video to reading a dry book (admittedly, the DJI User Manual is dry, but I've read mine several times and I'm still picking up little things…).
If you also like visual stimuli that actually shows you a step-by-step hot-to (verses a snap shot on a page…), here is a great video for beginners. It just might keep your bird in the air verses stuck in a tree…
Good Luck!
elitewikipublishers
