Hello, New pilot in central Alabama.
Welcome to the forum! :)
Hello from the Crossroads of America jmcfall313
If you havent done it yet, you should take the TRUST test and keep a copy with you when you fly.
It's a free no fail test that's easy to take.
Good luck and welcome to the Forum. :cool:
I have taken the Trust and have my part 107 certification as well.
Greetings neighbor from Birmingham Alabama USA, welcome to the forum! We look forward to hearing from you!
Just looking around the drone world.
Even with your TRUST and Part 107, I'll thrown in some Good Old Fashion Advice, since there was no "Road Test" to get either certification…
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Happy Droning…
EddieWhite97
