Hello
Welcome to the forum! :)
i am new in the drone world. I love create videos and i bought used Mini 2. I
Since you live in Serbia, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Fly On and Fly Safe…
Hello, i am new in the drone world. I love create videos and i bought used Mini 2. I hope for a good education here and good fellowship. I wish you good flying.
Welcome to Mavic Pilots from Dayton Ohio USA! Fly safe and have fun!
follaoret
