Anyone know how I can fix my camera lens or wher to buy a repair kit.
The camera looks good when flying but the camera lens is cracked 1/2 way.
Thanks.It is removable. Unscrew it. Then get thunderdrones involved.
Ok, thanks. How do I get ahold of them?It is removable. Unscrew it. Then get thunderdrones involved.
That's the actual camera lens. The Mavic Air camera does not have a removable UV filter. It's just an empty ring.It is removable. Unscrew it. Then get thunderdrones involved.
Hi! How did you fix the issue?Ok. So how do I fix it. Just remove the camera lens? Does someone sell it somewhere.
My Mavic Air has a unscrew cover over the lens, it's not just a ring.That's the actual camera lens. The Mavic Air camera does not have a removable UV filter. It's just an empty ring.
Mine had empty ring. Actual protective filter was glued on the lens kit. Maybe DJI modified design.My Mavic Air has a unscrew cover over the lens, it's not just a ring.
So your saying just crack mine more, break it out and put a filter on it?I've removed filter and successfully put 3rd party filter.
I met the same issue. My Mavic Air original filter had a 1/2 crack on it and it affected photo results.
After struggling to remove original filter for a hour. I accidentally broke the filter and it helped to remove it.
First, by gently and carefully push the center of the crack with sharp object such as small driver.
The filter will be easily break. You make the hole larger and larger then you will remove whole filter away.
Then put 3rd party filter on the outer rim.
Yes that’s where mine is broken. It’s the glass around the camera. The little camera inside is not broken. So I guess it would work.Yes. That's what I did.
You have to be sure that the broken one is the protective filter not actual lens.
This flat piece of glass is the filter. You have actual lens inside.
