Help! No RC connection, no WiFi, no assistant 2 connection
grdfbgb
Does anybody know how solve the problem with mavic pro:
The drone was updated by air to 01.04.0100 successfully. After that a perfect flight was performed.
When switching off after the flight the drone drone didn't allowed the battery to switch off (after switch off combination the battery stayed blinking one led for about 10 seconds).
The next start the remote was unlinked. It stays with yellow flashing LEDs.Tried all known pairing methods.
I did checked that the drone is in the RC mode.
The remote goes into pairing mode well both by app and the button combo.
The small led on the drone doesn't change from orange on small button press. (pressed many times with different objects to be sure)
So no pairing.
When switched into WiFi mode no WiFi hotspot appears.
When connected to Linux PC no /dev/tty* device appear
On Windows only
USB\VID_1AB7&PID_2100&REV_0100 USB\VID_1AB7&PID_2100
appears on a moment when the drone is booting. No other divece appears after the boot.
The ultrasonic sensor makes clicking sound. The gimbal works Ok.
Folders (DCIM, 100 MEDIA and others) are created on the sd card even if the card is inserted in a working drone. Particular this fact makes me believe that the main pcb is alive but stuck in some inoperative state.
Also after switch off combination the battery stayed blinking one led for about 10 seconds before switching off.Please give me an advice what to try.
The drone is on warranty up to March 2018. Defective focus was repaired by warranty in Germany last year. But now the DJI support in Germany refuse to repair the drone by warranty claiming they don't have global warranty and advice to send me it co China. And Chinese service refuses to repair it as they accept only drones from Chinese address.
So the only hope is from community.
Sounds like my problem also
I can fly it but it won’t hook to DJI Assistant
So it needs radar fix but I can’t do anything about it till it connects to DJI A
This sucks man
Buy something it should be repaired by company period
These Chinese have been screwing us for 50 yrs
Now they have a product that breaks and can’t be repaired
Sorry for the rant but we have a lot of money tied up for nothing
This sucks man
Have you tried update under linux?
howto:pyduml [dji.retroroms.info]
O'Ryan
