New to all this and found this forum very helpfull.
Are going to post my latest finding!
Hi LoudThunderWelcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar. Click on "Members" and then Click on "Member's Map…" Check it out and you might find some new flying friends.
Member Map
mavicpilots.com
Since you live in Denmark, there are specific laws and rules for you to follow, please check to ensure these are current.
"Denmark" - Drone Laws
drone-laws.com
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
I saw your other posting, so I know your Drone is a Mini 2… Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
DJI Mini 2 - Download Center - DJI
Learn and download DJI Mini 2 related apps, software, and manuals at the DJI Download Centerwww.dji.com
Fly On and Fly Safe…
Hi RichHilsen, Lemme, og velkommen til vores forum! Du finder meget her, der kan hjælpe dig med at vokse som pilot og fotograf. Danmark var det første europæiske land, jeg besøgte. Elskede det!
Rich R (Hauptmann)
Great adviceWelcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar. Click on "Members" and then Click on "Member's Map…" Check it out and you might find some new flying friends.
Member Map
mavicpilots.com
drone-laws.com
Welcome to forum, hope you enjoy and learn , cheers From Len in South WalesNew to all this and found this forum very helpfull.
