Hi from Winchester, UK
Welcome to the forum, from Hauptmann in Hurst TX (DFW area).
I've owned both the Mavic Pro and Mavic Pro II. Now I fly the Mini 4 Pro, and I LOVE it. It's totally the one to buy! Congrats on your purchase, Hope to see some of 1your work here on the forum! I recommend that you check out the YouTube videos by The Drone Creative. This guy will help you get quality shots easily.
Thanks for the advice, actually I do subscribe to The Drone Creative channel and have found it useful. There is always something to learn.I am finding drone communities to be friendly places and so it has been good to come in from the cold.
I'm a DJI Mini 4 Pro flyer and I am hooked
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
chrisjohnson0
