Hi I'm Neil, from Johannesburg South Africa
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching .👍👍
Hello from Minnesota USA and welcome to the Forum....There's a lot of good quality teaching/feedback going on in here. Just ask, and the experts are great on providing good sound advice for you to apply and use... Remember to always Fly safe, Fly Smart and keep the drone in sight.
Greetings from Birmingham Alabama, welcome to the forum!
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
Have you bought a Drone yet or are you still "riding" the fence, undecided what to buy, Good Luck with that!
Since you live in SA, be sure you are following all of the laws and rules applicable to you. Here is a DJI Link to Many Sites of interest to all, even those in the U.S.A.
Drone Flight Application Strategy Digest, continually updated!
Below is the link to all of the downloads offered by DJI for the Mini 2. You will also find the 75-page User's Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
DJI Mini 2 - Download Center - DJI
Happy and Safe Droning…
smittysflying
