My new Mini 3 shares the Mini 2's gimbal pointing/altitude difficulties.
If you want to ascend or descend and control the height of the horizon in the frame, you need to actuate both functions with the same hand - your left hand. This isn't easy and it should be. This is a basic, commonly-needed function.
The Mini 3 RC unit has two thumbwheels. If you could use the RH thumbwheel for horizon control and the left joystick for altitude, it would be a much more ergonomic solution and horizon management would be far easier for us newbie pilots.
DJI, please invoke this possibility via a firmware update.
