How not to forget the plastic part used to hold the gimbal
albbal
Hello
just to share this small tip
just make a hole in the plastic part (part who block the gimbal during transport)
use a small metal ring in the hole
and use a ribbon into the ring and make a knot
(and you can easily put on it the general round plastic protection
a red ribbon is easy to find with the chocolate box at this time of the year
thanks reading ;-)
Reactions: andybeach
Yeee. I probably will color mine red with a sharpie and label gimbal right by on button on the battery
I just ordered these on eBay. A 5 pack for under $2.50 shipped....
http://www.ebay.com/itm/5Pcs-Remove-Before-Flight-Embroidered-Canvas-Specil-Luggage-Tag-Label-Key-Chain/182377502593?_trksid=p2047675.c100005.m1851&_trkparms=aid=2220071&algo=SIC.MBE&ao=2&asc=38530&meid=8f82d13dc41b4976819036b73b543bac&pid=100005&rk=6&rkt=6&sd=221889258760&autorefresh=true
I've got it and it's not useful to use with the small plastic part
you can not closed the plastic bulb
nightram, that is similar to mine, got the idea from here
replace the key chain ring and use a small cord instead and it will allow the gimbal cover to close.
Rolling Horizons
