Any brand will work. Go to your local hardware store and pick up a package. Important,.....buy the size color appropriate for the wire size. Pink are for small wires, blue for medium size wires and yellow are for larger wires. I am not positive what size these wires are,.....but I am thinking pink will be correct,...certainly no larger than blue. These are pretty cheap and each package should cost you less than $5.00. And yes they will work just fine if installed properly. Because of room in the Mavic,...make sure you stagger where you cut the wires and install the couplers. (One cut a few inches from the board. The next cut an inch or so longer than the first cut,....and the finale cut longer than the second) This way you can tuck in the wires with the connecter without issues. Pay attention to this issue and you should not have any issues. Make sure you have a good crimper available.
Something like these are what you are looking for.
Hilitchi 100pcs 22-16 Gauge Butt Insulated Splice Terminals Electrical Wire Crimp Connectors: Amazon.com: Industrial & Scientific
They make another style,....but they take up more room.
Good luck.
Sent from my iPad using
MavicPilots
