How to add audio to Dashware
thrashr
Australia
Hey, is there a way to add audio track to Dashware?
I'm getting 'rendering error' when I create video and what I've read is it could be because of no audio.
How do I add audio to Dashware? I've searched everywhere but can't find any options inside the program.
Thanks
The guy to ask about that is this guy who made the Dash Video for the Air 2 Rescue Jacket:
It shows what is possible with the Dash and More.
Phantomrain.org
Gear to fly your Air 2 in the Rain and Land on Water.
Reactions: thrashr
Just create a batch file with this. Run the batch file next to the Video file and will create an silence audio track. You will need to download ffmpeg.exe.
@Echo off
set ffmpeg="C:\Program Files\FFmpeg\bin\ffmpeg.exe"
set audio_duration=1800
echo FFmpeg Add Audio Track
echo.
echo Creating silent MP3 file...
%ffmpeg% -y -f lavfi -i anullsrc=r=44100:cl=mono -t %audio_duration% -q:a 9 -acodec libmp3lame silent_audio.mp3
echo.
for %%f in (*.mp4) do (
echo Processing: %%f
%ffmpeg% -y -i "%%f" -i silent_audio.mp3 -c copy -shortest -map 0:v:0 -map 1:a:0 "%%~nf_audio.mp4"
echo.
echo.
echo Press any key to close...
pause > nul
@zeusfl
I realize this is an older thread, but I would like some help using your bat file.
1. Does the .bat file need to be in the same directory as the Video file?
2. Does the .bat file create the silent audio file, or is one that I already have?
3. How to you 'Run the batch file next to the Video file' if there are many files in the same directory?
4. Will the newly modified file be named as the original, or something appended to the name?
Thanks in advance
1- Download FFmpeg from here.
Builds - CODEX FFMPEG @ gyan.dev
2- Follow this instruction to install FFmpeg.
How to Install FFmpeg on Windows: 15 Steps (with Pictures)
3- Modify the my batch file for the FFmpeg.exe location. Is different than the original one. Check the Red font below
4- Put the Mp4 file together with the batch file and run it.
@Echo off
set ffmpeg=
"C:\FFmpeg\bin\ffmpeg.exe"
echo.
echo.
echo.
echo.
pause > nul
Check this video I just uploaded for you.
Reactions: pyrolator
Dragsen
