How to play 4K video on iPad
richtroy
I have the Apple iPad mini 4 that I use as the display while flying the Mavic Pro.
Today I put the SD card from the Mavic Pro into the Apple SD card reader for my iPad mini 4. The iPad Photos app recognized the 4K video as content that it could import, and it did the import when I selected the 4K video.
The iPad Photos app would not play the 4K video, saying it did not recognize the video format.
I downloaded the DG Player from the iPad App Store and it played the 4K video perfectly for me on my iPad mini 4.
Reactions: Speedy
.mov is for iOS apple products. If it is set to MP4 it will not work unless converted. If u use apple products record in .mov.
I have the same problem with my iPad Mini 4 and trying to play .mov 4K video files.
Reactions: Gumby
It's an issue with the iPad mini 4. My iPad Pro plays .MOV and .MP4 4K files without issue. I actually don't use .MOV anymore, since the only Apple product I own is the iPad Pro.
I just got the same results on my iPhone 6 Plus
Guys this is how i understand it
iPad Pro A10 processor = yes 4k is compatible
iPad mini 4 A8 processor = Maximum 2.7k compatible
iPad mini 1-2-3 with A7 processor = not sure what works
So you need iPad pro & the A10 to edit 4k on any sort of iPad
Stuart
Reactions: SxSmith
I have the same problem with my ipad air 2 and my iphone 7 plus. From camera roll is not compatible the 4k video
....The iPad Photos app would not play the 4K video, saying it did not recognize the video format.
For those that don't read the whole OP before replying. :rolleyes:
Thanks for the info... I'll be looking into this DG Player app as well. Thumbswayup
Although the 4K video recorded with DJI Mavic Pro are using with compatible H.264 codec and MOV container file format, however, you will encounter other playback issue due to the unsupported frame rate, bit rate, sample rate, channels issues, etc. To fix the profile incompatible issue of Mavic Pro 4K with iPad series, you can turn to help with a 4K video converter app to tweak the source video files.
artyboy
