How you reset gimbal direction ?
Valyo
What is the way to reset gimbal direction ?
As you know if you touch the screen with finger and move it - changes the gimbal direction.
But how it can be reset to forward direction ?
I have set button for FPV/Follow mode but it does nothing.
Using M2 Pro with Android app.
Thanks V.
As mentioned above C1 will do it if you have that setup in your settings in DJI GO 4. It should be set to "Camera Forward/Down". This is not the default setting though, the default setting for this is actually moving the 5D joystick up or down (the 5D stick is the small little joystick by the RC screen)
Reactions: Valyo
theory81
