Howdy Again
Zarro
Pipe Creek, TX
I had already said hello over on the EXO page, as I started out on a Cinemaster 2. But it's a ghost town over there and I am now workin with a Mavic Air 2. So I am re-introducing over here, instead. I fly in the Texas Hill Country and am investigating turning this into a side hustle, with a possible focus on mapping and surveying. I am first building time and getting my Part 107 plus adding some tools and skills to my toolbox. Very interested to hear others' experiences and paths in here, so chime in and let us know what's up!
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
I know you are working on your Pat 107, but in the meantime, if you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
Link to the FAADroneZone…
Since you live in Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Air 2, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum @Zarro! :)
destinyrett
