Howdy from Oklahoma
Doooooooo
t
Howdy from Oklahoma, Got interested in Drones 7 years ago, flew a Typhoon Q500 and original Zino, had trouble with neighbor trying to shoot them down, wife made me quit. Got back into it 6 months ago with a Potensic Atom, recently got a Mini 4 pro and a Neo, not done much flying up to now, still trying to overcome the dreaded Drone Anxiety.
Welcome to the forum from the UK!
If you neighbor does shoot your drone down, that will probably be the last one he shoots down, it's a federal crime to shoot one down and discharing a weapon like that might also put him at odds with the local authorities…
But as an almost New Drone Pilot, there are a couple of Legal Things you may need to do as the laws have changed over the years…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Oklahoma, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members who are willing to help you with any questions you might have. Search the forum using keywords and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response.
Fly safe, enjoy and stay safe!
john_b3t
