Does it work to your satisfaction? Can you control the time between visualized frames?I use Microsoft Hyperlaps pro.
I received my complementary product key via promotion type deal via email but it is the same key that is listed here,
Promotional - Free - Microsoft Hyperlapse Pro (Was US $50) @ Microsoft
I don’t have knowledge of how an M2P does it, but here’s how I do it with the MPP...How to..?
That’s how it works in the M2P (DJI) method. I uses it a lot for sunsets. The photo interval can be set for 2,3,5,8.... sec intervals and the aircraft stitches into a video that is stabilized.Well yea I guess for what it does and at zero cost isn't a bad thing either, also takes the processing load off the aircraft.
Works a little differently than DJI, in their version as I understand it (someone please correct me if I'm wrong) it is done taking a series of pictures then when finished stitching them together creating the end resulting video.
MS HL Pro takes any video you have, taken with a drone or otherwise (does not natively recognize DJI camera) then takes images from that video at a speed, frame rate and resolution you choose, stitching them together for the same end result.
Would I have paid the 50 bucks for it? no probably not but I don't use it much either but same time handy to have loaded in case I want it.
Me too!Yes thanks for verification, I seen your post #5 you had posted while I was typing out my reply #6. I was taking a few minutes looking over the software. It been a while and wanted to verify couple of points before posting about it in any amount of detail.
Well that plus I'm just slow on the keyboard!
