I made a hyperlapse recently. The processed file was on my card but the individual stills were not there. Is there a setting to keep the stills that I might have changed? Has anyone else had this problem?
Thanks
Thanks
I think it’s just how it works when the vid is synthesized from all the stills. You can grab clear ones from any video editor.I made a hyperlapse recently. The processed file was on my card but the individual stills were not there. Is there a setting to keep the stills that I might have changed? Has anyone else had this problem?
Thanks
Yeah, but that is just the math. You can plug in whatever time you want to get the frames that will you will need. So if you need 300 frames for a 10 second video you will create in post at ~30fps, then you will need to specify more time in the DJI dialog.Excellent. That’s what I needed to know. Thanks for taking the time to reply. Why DJI decided on 25fps is beyond me.
It has to do with DJI Image processing. The edges of the image are more severely distorted than the center part in the raw image. DJI processes these raw images to reduce this distortion before creating the output images.
