Hey guys! Long time lurker, first time poster. Long story short, I crashed my Mavic Pro yesterday - I took off from the spot I normally take off, which is between my house and the neighbor's house, which is ~15' wide. Made all the pre-flight checks and all looked good (sats, battery, no weird noises). MP took off fine manually and started quickly drifting off to its right side at about 10' elevation, I tried correcting it and was successful, but then happened again but unable to recover and it hit the side of the house, then dropped altitude to ~4' and hit the side of the house again while flying uncontrollably, then slammed into the rear of the house at which time I killed the propellers and dropped on grass from ~7'. Post-crash assessment shows that 3 propellers broke, clipped and scratched. There is minimal scraping along the battery and rear of the body, and there is a hairline crack on the rear plastic wing that extends past the leg support, which leads to believe that the rear leg took the impact. It does not move unless I place pressure on it, and the leg mechanism moves normal when taking it from folded <-> unfolded. All other legs/arms move fine with no play, motors turn without resistance manually and while powered on, gimbal works as expected, no problem with AF. After work I took it for a test flight with all new propellers and all works as expected - all controls respond like usual, although it was very windy in the evening when I tried the test, so it drifted and moved quite a bit...so I'm waiting for the wind to die down to try it again.
Overall the only damage looks to be the scrape on the battery and rear body, and the hairline crack on the rear leg support plastic wing. Soooooo my question is if it is worth having a professional inspect it? For full disclosure I bought this MP 2nd hand off a guy I know, who had it for 1 1/2 years before I did, so no DJI care or warranty is valid at this time, so all charges will be out of my pocket. I take care of my things, so if y'all think it's smart to have it checked out after this crash I will look into it, but from a test flight all looks normal .
Any advice or suggestions are much appreciated.
Thanks!
Thanks!
