I think Timinator and ChipDjipro called it. At this point probably toast. I have been boating for 30 years or more and we used to use a method called "Pickling". If you sank your boat you might (if you could retrieve it) be able to save the motor by keeping it immersed in whatever you sunk it in (fresh or salt). You would keep it immersed by way of a Barrell or large tank and if if it was salt water you would keep running fresh water until you thought all the salt was out and then try to get a large amount of distilled waster to flush it further. This if made easier wit a drone because of the size. It's probably too late now, but in the future (besides buying the insurance) you would put a bucket under the drone, scoop it up, bring it home and run fresh water for a half hour or more to get pond scum out. Then, while keeping it submerged, (oh, btw the first thing you do is take battery out) scoop it up with a smaller container and fill that container with distilled water. Let it sit in the distilled water for a day every once in a while shaking it to get sediment out. Now put it in the smallest container it will fit in and fill container with isopropyl alcohol and let sit for another day. Take out of alcohol and let it sit for a week. You might save it but it is kind of a crapshoot.
